Results 1 to 4 of 4
    Member Lucki1's Avatar
    Aug 2015
    Default Airbag Ford Ka 51800461 B0100 B0101 problem
    I have Airbag with 2 dtc: B0100 B0101
    i change airbag module ( i copy 95320) and is the same problem.
    Pls help
    ateyourv8's Avatar
    Feb 2018
    Down Yonder
    Check fuses for airbag module. That should at least fix the power supply dtc. If fuses are good, check for voltage at the power supply wire to the module.
    Why did you copy the eeprom instead of just changing the entire module?
    Aug 2015
    ok i now check
    different coding in new sensor
    Top Poster rozario's Avatar
    Hi ive same problem B0100 B0101 can somebody post clear dump or clear my please
    attached 95320
