Results 1 to 4 of 4
    mancioks's Avatar
    Feb 2017
    Germany
    Default PCR2.1 dealer updated software or not by dealers log
    Hi. My friend has a problem with golf 6 1,6Tdi PCR1,6 that cold engine is not running smooth. He went to dealer and asked to check injectors. When he took car he was said that they did software update and injectors adaptation. But strange thing is that car that was tuned is still tuned. As i work with mostly opels, if you update software, car should be stock. They also sent log from works. Can someone check if it was realy updated? Car has same simptoms after all and bigger consumptions
    PierreTheron's Avatar
    Centurion,South Africa
    So dealer software not regocnised that it was tampered with m8..
    mancioks's Avatar
    Feb 2017
    Germany
    So if it not recognised changes it was not updated/changed?
    mancioks's Avatar
    Feb 2017
    Germany
    No more ideas?
