Results 1 to 5 of 5
    Senior Member smotorsport's Avatar
    Feb 2018
    Default Passat B5.5 2.5TDI EDC15VM Checksum problem
    Hello, I have a problem with the cks on 2.5tdi edc15vm. Ols dont recognize the cks on the remapped file. When I write the remapped file to the car it didnt start and no ecu id so i repaired by desoldering chip. I use galleto for reading/writing which doesnt support checksum correction for edc15vm. Tried ultimo and again no luck. Can somebody please make te checksum for me. I upload archive with the ori file, remapped file with ols checksums, and remapped with deleted checksums (keep original values). I need 100% working cks because dont want to desolder again Thanks in advance.
    Europe
    file 100% ok
  3. The Following User Says Thank You to Yura123 For This Useful Post:
    smotorsport (12th December, 2018)
    Feb 2018
    Here I tested again with winols to correct and I might succeeded... Can someone confirm please?
    Feb 2018
    Thanks Yura. My last file looks exactly like yours. Thank you very much. Will test tommorow and repport!
    May 2018
    VAG VE/PD/PPD TUNER
    FILE SERVICE AVAILABLE
  7. The Following User Says Thank You to marcusbs61 For This Useful Post:
    smotorsport (13th December, 2018)
