Results 1 to 11 of 11
    Feb 2013
    UK Bristol
    Default Ford Edc 17 Clone advice
    Hi there. I need clone ecu 1 to 1
    Car Ford Fiesta VI 1.6 diesel
    Ecu EDC17C10
    I got ready backup from oryginal ecu readed throught ktag and need copy to Another ECU
    Both ecu have exacly the same bosh numbers.
    So it is chance done this throught example ktag without any adaptation after
    If yes how os the process
    Thanks for advice
    My post helps you? Please Hit Buttons
    Feb 2013
    UK Bristol
    Nobody helps..
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    search on goolge...... EDC17C10 clone
    i am sure you find the answer.....
    honingkoning's Avatar
    Dessert
    Quote Originally Posted by pocinas View Post
    Ecu EDC17C10
    Thanks for advice
    Did you solve your problem???
    Feb 2013
    UK Bristol
    Quote Originally Posted by honingkoning View Post
    I tried but without lucky
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    Dessert
    I was able to clone this Ecu by writing flash from ori ecu to other Ecu.
    Did it with gall ori.
    Wbr
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    Wbr
    transfer and the immo too ? in otp area? interesting....
    Dessert
    Quote Originally Posted by Panathaole View Post
    A lot of of edc17 can be cloned.
    As far as I know vag is the only one with immo inn otp area.
    Recently I did a BMW Ecu msd81, also possible to clone it
  10. The Following User Says Thank You to honingkoning For This Useful Post:
    Panathaole (24th February, 2019)
  11. #10
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    So just the question in first post just get an answer.... swap full bdm reading to donor ecu, and that's it....
  12. #11
    Dessert
    Yes that's it
