Results 1 to 2 of 2
    Dec 2018
    Default communication trouble with VAG14 obd interface and vcds, "security Access " greyed
    i have an ald obd china clone (VAG14), the clone has the firmware 1.94.
    mcu: D79F8513A
    MCP2512
    FTDI:ft232bl
    , last time i had used it with win7 and vcds 15.7.1 - all things worked fine.
    Because i must change the steering sensor, i have no abs/esp function.
    Because i want teach my steering sensor, i try to use my obd interface.
    For this i installed vcds 15.7.1 in my win10 OS,
    After the driver installation i can find the interface.
    If i connect the interface to pc, it can find the interface.
    If the interface is connected to car i can read out errors and clear it.
    But i can't teach the steering sensor because the "Security Access" button is greyed out.
    Could it be that the downloaded version will not work with my interface - or how coul it be that security access button is grayed out?
    I hope somebody has a solution for me.
    aS I SEE AT THIS TIME - what i have SEEMS TO BE the Avtoadapter VAG-Com HEX-CAN chip NEC D79F8513A
    Anybody could help?
    Best regards
    Meat-Head's Avatar
    Yeah, have to be vague, options, settings, test
    somewhow it's gone to "home basic dumb person mode"
    test check etc see if comes to life mine did that not sure what I dud
