Results 1 to 3 of 3
    Jan 2014
    South Africa
    Default NISSAN KEYLESS NEED HELP IMMO OFF
    Greetings all, need help with immo off or solution with the nissan tiida 2005 model with the keyless entry, the client lost the key, can someone advise what steps to take here ,this vehicle is an imported so there is no parts available where i am here, is immo off possible or lock set for a same model tiida i will post the dumps or part numbers if requested
    thank you
    CHIKO's Avatar
    Jun 2014
    hi you need to post more information of your ecu and if you have the good tools you can maike a new key
    good luck
    Jan 2014
    South Africa
    Thanks,when u say good tools which tools would it be,i got a orange 5 and skc 1000,what would u recommend.
