Results 1 to 9 of 9
    Fec001's Avatar
    Default Peugeot 207 MEV 17.4 Immo off
    Hi!
    Please switch off Immo in this ECU:
    MEV 17.4
    0 261 S04 009
    HW 96 652 911 80
    SW 9663193780
    SW Upg. 9665268180
    Many thanks!!!
    Fec001's Avatar
    Default dump
    Can someone check if this is a working solution please? Car is far away from me.
    Jan 2014
    Default immo off
    try and report,
    this immo off 100% ok
  4. The Following 2 Users Say Thank You to chafik4051 For This Useful Post:
    egycyclops3 (18th July, 2019), Fec001 (14th December, 2018)
    Quote Originally Posted by Fec001 View Post
    Checksum not calculated, engine should start a couple of times.
    Jun 2014
    ankara-turkei
    Quote Originally Posted by Zmann View Post
    yes car will not start after some times but its not checksum problem..its wrong algo
    psa med/mev algo very different than others
    Le-Mans's Avatar
    Jun 2017
    if your problem not solved i have tested solution
    baltazar3's Avatar
    Andromeda
    Quote Originally Posted by LeMansSeries View Post
    If You have tested solution why dont post here ?
    '" live and learn........ if you wont ....you ain't "
    _______ . ____ . __ . __ . _______ . __ __ __ ... ---
    If my post was HELPFUL please push THANKS button
  9. The Following User Says Thank You to baltazar3 For This Useful Post:
    Le-Mans (30th December, 2018)
  10. #8
    Fec001's Avatar
    Thanks all. chafik4051's solution work well.
  11. The Following 2 Users Say Thank You to Fec001 For This Useful Post:
    chafik4051 (17th December, 2018), Le-Mans (30th December, 2018)
  12. #9
    Le-Mans's Avatar
    Jun 2017
    Because chafik4051 post one solution if not works i believe Fec001 reply back in threat without solved problem
  13. The Following User Says Thank You to Le-Mans For This Useful Post:
    rafal (1st October, 2020)
