Results 1 to 1 of 1
    Default CITROEN C4 1.6 16V REMOVE DTC´S
    HI can anybody help me with this?
    I have a citroen c4 1.6 16v
    0261S06472 MEV17.4.2
    and get this codes:
    p1336
    p1337
    p1338
    p1339
    p1340
    all fauts refers to ramdom combustion cylinders failures,i try to remove this codes from the flash with a software but the light comes again and the ecu disconnect one or two cylinders although in the scanner not appears this codes yet.
    is possible remove all(dtc´s,engine light and disconnection of cylinders)?
    i can pay for a tested solution
