Results 1 to 14 of 14
    Sep 2018
    Oradea Romania
    Default Renault Laguna PH2 - 2007 CARD
    Hello ,
    I tried to make a new card for an Renault Laguna PH2 - 2007 year.
    I tried with FVDI 2018 , but didn't get out the PIN CODE. When i click GET PIN CODE , tells CANNOT READ PIN CODE.
    Tried with Renault CanClip , and when i try to program new card , give's me error
    COMMAND IMPOSSIBLE - Execution conditions unsatisfactory
    With same FVDI i made card on other laguna , without any problem.
    Can you please give me some ideea ?
    France / Serbia
    Ok mate, the problem is you car reader
    open it and you need found a broken plastic inside under the card
    try to push the red button with paper and program your new card
    SA VEROM U BOGA, SLOBODA ILI SMRT
  3. The Following User Says Thank You to danyparis For This Useful Post:
    DaBotta (16th December, 2018)
    Sep 2018
    Oradea Romania
    Thank you mate ,
    Can you please explain me.
    I saw some videos with that button. But what i don't understand is .... when you pull out the card , the button become unpressed. If the clients reader has the plastic broken , the button is all the time unpressed. And if it's unpressed why returns error , and not working to make card ?
    Thank you
    panos_k's Avatar
    GR pankar
    Hi, inside the reader have two button and over two plastic. Open the reader and check the plastic if is broken.
    Louislesinge's Avatar
    Jun 2017
    French Jungle
    First to confirm the problem in the switch: how does the car starts with the original card? Do you press "start " by one short impulse (it means switch OK) or do you have to hold "start" until the engine runs ? (this means lamella over the switch broken).
    Second, does the door stay open while you try to learn the new card?
    Greetings,
    Sep 2018
    Oradea Romania
    The car starts only if you keep the button pusshed.
    The first step of the contact don't work , when you put the card inside. The car reacts only when you fully in push the card.
    France / Serbia
    This is 2 pics found on net
    One with red Button the second repaired with paper or plastic
    when you insert the card, the card pusch the plastic and the plastic press the button
    Jun 2017
    French Jungle
    Quote Originally Posted by DaBotta View Post
    Then follow the good instructions of danyparis and panos-k, they are right.
    Greetings,
  10. #9
    Sep 2018
    Oradea Romania
    Thank you all for the answers. These days when the client will have time , i will try to fix the reader and after that try again to make new card.
    I will send the updates
  11. #10
    Sep 2018
    Oradea Romania
    Well , today i had tried again to make new card to this Laguna.
    Same problem... Cannot read pin code.
    I hade solved the problem of the reader. The plastic was broken , i had glued and all worked wll. Now the reader works like this.
    When you insert the card , the radio turn on
    When you insert to the end , the ingnition is turning on
    And don't need anymore to keep pressed the start butoon. Just a simple short push on the button and will start.
    But no pin code
    My tool is FVDI 2018. Tried with booth software version from the loader for Renault. And no pin.
    Do you have some ideeas ?
    The car is from 2007 Laguna 2 PH2 , the one with the renault sign in the front grill ( the facelift )
    1.9 DCI Engine.
    Thank you
  12. #11
    Dec 2016
    ISK is encrypted use RenOlink to get PIN code & program new card
    https://fr.aliexpress.com/item/Renol...27426c37WYyj3m
    the FVDI 2018 is online use ? TIME LIMIT ACTIVATION ??? what version of VVDI2 is activate ????
  13. #12
    Sep 2018
    Oradea Romania
    FVDI 2018 it's activated , and with other cars and even Renault Laguna worked.
    With this tool you posted here , can i writed CARD ?
    Thank you
  14. #13
    Dec 2016
    Thank you
    Yes you can !
    , where you bought it ?
  15. #14
    Sep 2018
    Oradea Romania
    I had ordered now from aliexpress. We will se when will be here.
