Results 1 to 12 of 12
    epicsabi's Avatar
    Budapest
    Default Suzuki Splash 2013 Autoliv 38910-80MA0
    I need help with clear for this controller
    38910-80MA0
    623 69 84 00
    Autoliv
    95160 eeprom
    THX
    slick_dick's Avatar
    Essex
    that file looks clear??
    whats the fault codes
    “There's nothing more dangerous than someone who wants to make the world a better place.” ― Banksy
  3. The Following User Says Thank You to slick_dick For This Useful Post:
    epicsabi (14th December, 2018)
    epicsabi's Avatar
    Budapest
    Quote Originally Posted by slick_dick View Post
    I read with Launch
    epicsabi's Avatar
    Budapest
    Please help...
    superjet's Avatar
    Aug 2018
    Try this and report back.......
  7. The Following User Says Thank You to superjet For This Useful Post:
  8. #6
    epicsabi's Avatar
    Budapest
    Quote Originally Posted by superjet View Post
    I tryed with your solution but unforunetelly not work
    Same DTC
  9. #7
    slick_dick's Avatar
    Essex
    Quote Originally Posted by epicsabi View Post
    Same DTC
    i only found 4 bytes compared to other alogs of same car
    pass in pm
    if this works i will slap meself!
    good luck
    slick
  10. The Following User Says Thank You to slick_dick For This Useful Post:
  11. #8
    epicsabi's Avatar
    Budapest
    pass in pm
    good luck
    slick
    Thank you mate but unfortunetelly not work...
    I tried this before
  12. #9
    dmka's Avatar
    Oct 2013
    Vatican City
    Anyone else worked on the module before?
    Missing info in line 6E0 and 6F0 ?
    Compare to my files, clear 100%.
  13. The Following User Says Thank You to dmka For This Useful Post:
  14. #10
    epicsabi's Avatar
    Budapest
    The problem solved...
    The Launch diagnostic device read the DTC "B1051 crash recorded" .... and this DTC in Suzuki DTC table ...Driver seat belt pretensioner circuit high resistance. :-(
    The car is works well with original file.
    Thanks for help guys
  15. #11
    dmka's Avatar
    Oct 2013
    Vatican City
    Yeah... a good scanner helps a lot.
  16. #12
    slick_dick's Avatar
    Essex
    see told you the first file was good
    thanks for the share
    unbelievable
  17. The Following User Says Thank You to slick_dick For This Useful Post:
    tamer1024 (15th December, 2018)
