Ok so i ordered a tool that will do this remote but what eeprom am i reading to code the transponder?
If i helped please press the thanks button
Read BMW EWS with AK90. Skinned knuckles getting the bastard out. Keydiy remote and ISTA D to program the remote is what I use.
It's down in the driver's footwell. Screwed to the bulkhead.
No. Much lower down. Down by the accelerator pedal - on a rhd car anyway.
paulsta (16th December, 2018)
Mini, 2002
I,ve created 2 keydiy remotes, with codes.
Using a mvp clone, i whas able to clear old remotes.
And enter 2 keydiy remotes.
I can see that they are programmed in, but not work.
Dont know why.
Is there more to it then entering these codes?
Hello,what is the cheapest option of programmer to adapt the 2 button remote?
thanks in advance
Cheapest is definitely INPA cable, costs only a few bucks. You can then use Tool32 or ISTA/D.
(ISTA/D is probably the simplest and has the most tutorials available)
You'll have to connect Pin 7 and 8 together. You don't need K+DCAN but I think the old one is not available anymore.
newone (3rd February, 2019)
Could you show us, where the 1999-2003 mini remote adaptation is. I tried with inpa, it did not support these.
This is a Rover remote system, that needs inserting the long pin on the key label.
Mvp should be fine, i suspect the car i tried it on to have a waterdamaged control unit.
My experience is that the versions of INPA going about don't support the Mini BCM.
I'm told a £100.00 clone mvp Pro does them. I'll know better after the Chinese New Year.
On ali, they have the : V17.8 T-300 T300 Key Programmeur, about 90 euros.
Same as the square mvp, but a bit improved and cheaper.
It dont have it myself, but if you look at the pictures on ali, you will see the mvl logo in the screen.
newone (4th February, 2019)
thanks Robbert but he said mvp pro and i was a little confused for the price he mentioned
