Results 1 to 9 of 9
    Jan 2018
    Default possible write kess clone 5.017 toyota 2.2d via obd
    hello i want ask is possible write file via obd for toyota/lexus 2.2d ?
    kess 5.017
    thanks and best regards
    May 2017
    Yes but with ori alientech toyota cable
    Chiptuning Files FileService, Damos Files
    EGR/DPF/NOX/DTC/TVA/VSA/ADBLUE/Lambda OFF...
    Licensed: WinOLS, RACE 2000, ECM Titanum, ESS
    Master: Kess,Ktag, HPTuners,
    no personal info in sigs !!!
  3. The Following User Says Thank You to gmon16 For This Useful Post:
    Richi777 (15th December, 2018)
    Dec 2018
    I done lexus with normal OBD cable
    Dec 2017
    You can On if it’s above 2006 Model
    If it’s below 2006 it’s Kline and different cable
  6. The Following User Says Thank You to Happy786786 For This Useful Post:
    Richi777 (16th December, 2018)
    Jan 2018
    is a lexus from 2009 year 2.2d 177hp
    cannot flash over obd say me weong prozess after kess ask for different need ori file
  8. #6
    Dec 2017
    I’m not too sure whether you can flash with the clone Kess
    But you’d need the Original file first to try
    Or you can with Ktag
  9. #7
    Dec 2018
    I’ve flashed with Kess 5.017 2.23 and 2.47 just make sure file writer has access to databank gives you mod and original for comparison
  10. The Following User Says Thank You to MVRH For This Useful Post:
  11. #8
    Jan 2018
    Thanks for all i have solved this problem have chks problem
  12. #9
    Dec 2018
    Glad I could help
