This is possible only if you have the password for the car that locked it or the dump from that bcm/cluster
from personal experiance , not all id48 chip can be unlocked , some will unlock and other not , with zedbull , on older vw 2003 2005 i have unlocked them , but again not all , will unlock , then u can pre-code it again for you vag model , if it is for vag car
Ask a dumb question and become wise for the rest of your life, but act wise and stay dumb
If the password is known, it will unlock.
Some i unlock with vvdi2, some with Tango.
I have some keys from park with distroyed cars , so don't know password.
So can't do anything with them ? All of them are ID48 CanBus
If you write some software you can easily brute the right pincode/password.
It will just take some time ...
What software?
Thank you
Trimis de pe al meu SM-G935F folosind Tapatalk
Some times will be very long. Several years for brute force one
No, it is just a 32bit pincode, so can be done pretty quickly.
You're absolutely right, it will take too long
THIS TOOL IS PERFECT TO UNLOCK ID48 AND OTHER REMONTE https://fr.aliexpress.com/item/KEYDI...857450652.html
