Results 1 to 11 of 11
    Dec 2018
    Default Help for 'SAM' Smart fortwo
    Hello everyone,
    I am looking for the best solution to replace the 'SAM' on my fortwo 450.
    He took the water, it remains functional but there is damage on the circuit board and some outputs work more (lighting switch air conditioning / horn).
    I have another 'SAM' used but I do not know how!
    Should we make it blank and after reprogramming the vehicle settings or cloning the old?
    Thank you
    Jun 2013
    Call "Uncle SAM" to solve this
    https://www.youtube.com/watch?v=kHYiyv68q2o
    https://www.youtube.com/watch?v=OnS2ut89rKc
    I think Star is the way to go. Purchase or lend. Or contact a workshop to help you out.
    Or you can order a Technician home to your place, to solve it where you are located.
    figani's Avatar
    Feb 2018
    47 45 52 4D 41 4E 59
    Quote Originally Posted by willy6609 View Post
    Hello everyone,
    Thank you
    the new used one... does it has the same part number...?
    post photos...?
    Just built it in and connect like the old one...
    when you have star, use under SAM, immo adaption... car will start...
    when you have FVDI 2014, choose Special functions, SMART Adaption, Immo... car will start...
    or use reader and clone flash/eeprom... when same... car will start...
    When I help you press Thanks and Reputation...
  4. The Following User Says Thank You to figani For This Useful Post:
    willy6609 (17th December, 2018)
    Dec 2018
    The serial number is the same:
    00 11868V011 SAM
    5WK4 5090
    Since I do not have Star and I do not have FVDI, I thought I'd make a clone. In addition I thought it was not possible to change the VIN No. in a used SAM.
    Is it possible to make a clone with UPA USB or Xprog?
    Otherwise what software will you advise me?
    Thank you
    figani's Avatar
    Feb 2018
    Yes, clone it...
    Xprog will make it...
    When you change VIN in Eeprom, you'll have to calculate checksum...
    So it's easier and faster to clone it flash/Eeprom...
  7. The Following User Says Thank You to figani For This Useful Post:
    willy6609 (18th December, 2018)
  8. #6
    Dec 2018
    To avoid an error, have the pinout for reading?
    You have to connect 7 wires because it is secure, is that it?
    Thank
  9. #7
    Dec 2018
    hello,
    Should it read in normal or secured mode?
    Thank
  10. #8
    Dec 2018
    Please .
    Thank
  11. #9
    figani's Avatar
    Feb 2018
    As I know, itīs NO Secured...
    4 lines, vcc, ground, reset and bkgd itīs standard...
    here you have Pinout...
  12. The Following 4 Users Say Thank You to figani For This Useful Post:
    jaxxxer (6th February, 2020), merlinspitfire (17th February, 2022), Stelaras26 (14th April, 2020), willy6609 (13th March, 2019)
  13. #10
    Dec 2018
    Thank you so much .
    With your pinout, if I'm not mistaken you put the 5 volts on pin 31 (XCLKS)?
    That's right ?
  14. #11
    Oct 2018
    Hi, is the smart sam unit_zip.rar file password protected?
