disconect egr plug
disconect egr plug
Chiptuning Files FileService, Damos Files
EGR/DPF/NOX/DTC/TVA/VSA/ADBLUE/Lambda OFF...
Licensed: WinOLS, RACE 2000, ECM Titanum, ESS
Master: Kess,Ktag, HPTuners,
no personal info in sigs !!!
dashtool2016 (16th December, 2018)
disconnecting the plug of the egr works the same I do not have power: S how can I fix it? did you check my file? egr is it well annulled? Is there another proven solution? Thank you
Hi, you closed exhaust gas recirculation channel?
Or was ok before delete egr?
I can help you.
Alientech KESS + KTAG, MagPro2 X17, FLEX Flasher, AVDI by Abrites, WinOLS Genuine Full, Maha LPS3000 Dyno machine.
