Results 1 to 3 of 3
    Feb 2012
    Default Peugeot 206 lift 2005r. 1.4 KFW
    I have a problem with this car. Sometimes when I start engine then is no reaction to acceleration pedal. I switch mamy time ignition switch and then is ok. ECU write fault p0608 - vehicles speed sensor wiring. The car doesnt have this sensor. Anybody have a that problem ? Please help
    Thanks for advance
    Member trivilin8's Avatar
    Mexico
    If there is no other fault code but vehicle speed sensor (which must have but has nothing to do with the fault) then check fuel pump pressure, could be either fuel pump or bsi which has the relay to activate fuel pump. Check fuel pressure and we'll power fuel pump with tester
    Dec 2018
    Check signals (2) from pedal position sensor, on ECU when it happens.
