Hello All
Newbie so go easy please
I know Keydiy go up to 2009 for Seat Ibiza.
Has anyone done 2010 model ?
If so which remote and code is best to use ?
Thanks in advance 👍🏻
J
Hello All
J
Use 1KO959753N too this car
Verzonden vanaf mijn iPhone met Tapatalk
Jimmy07 (16th December, 2018)
Thanks -mustafabahar
It’s for a job in the morning have OEM key for back up but if can pop an ID48 chip in handy baby and pre code then use Keydiy be a good looking cheap key. Doing bit of research now before I hit any job saves time and takes guess work out of it. Weather is grim here so if I can have remote ready and chip pre coded tonight in the heat will save 20mins i could use getting to next job tomorrow
try the suggested 1KO959753N first , if no joy then try 4th generation , one will work depending if NEC or UDS
is this all keys lost or a spare ? and what kit are you planning to use ? especially if all keys lost.
Jimmy07 (17th December, 2018)
Hi Rapid
No just a spare key job. Using handy baby to generate chip then key learning with Supervag
Will a keydiy nb remote, not do these?
isnt nb remotes for id46 applications ?
keydiy b series remotes work on these fine
All sorted set up Keydiy B series with code provided by -mustafabahar and Rapid, cut key and pre coded chip with handy baby. Set up Supervag key learning and added key. All good but remote not working. Used MVP to program remote ( no tokens) and away it went. All buttons working and a happy customer
Does key learning with Supervag not program remotes ?
Thanks for everyone’s help
it does on alot but you have to code remote after chip , they dont code in at same time , so with supervag you must emter the remote coding menu
Thanks Rapid
Was looking for remote programming but didn’t see this option on Supervag menu for the Ibiza ?
Maybe shows after key is programmed and you go back in again ?
Got there which is the important thing
its at top of screen when you choose car , you have remote programming , key learning , read pin etc
I didn’t see remote programming at top of screen it went straight into auto detect and give me key learning and programme key option ?
I’ll plug it into my Tiguan tomorrow have a good study at it also back to more reading and video watching
Thanks Rapid very few would take the time to answer newbie questions it really is appreciated 👍🏻
kostelectronics (20th December, 2018)
Please help me ! Im newbie in key area
I have now Seat Ibiza IV 1.9 TDI year2009 ecu edc17u01
I want to add new key with remote control, can someone explain to procedure please? ( with fvdi )
I have blank 1K0959753G , I have long time searched and found it that I need to transponder pre-code to CS, but how ?
