try this dump....ist same.....tnx
Col19 (17th September, 2023)
According to your eeprom you need this:
WBR, Marek
vasa (17th December, 2018)
This is pure bin.
For Rosfar you need it crypted.
WBR, Marek
Did you use bin file with UPA?
Because rosfar is just for Rosfar.
WBR, Marek
Write both eeprom and flash. It should be plug and play. If not just code it. No PW.
Hello Guys ia have issue with E91 335D not possible turn on ignition not work key hole if i put hart cluster turn on (not ignition)
all ecus is offline i mean cas is dead data
61.35-6943830-01
I need flash to this cas3 Mask 0L15Y
61.35-9237047
please fix eeprom or flesch
If I helped, please, use magic buttons reputation+thanks.
no sync with ecm and cas
more information
who said that sync is lost?
your file is cas3 crypto with 16bit ISN
doesnt need to be synced
