Results 16 to 30 of 31
  1. #16
    Jun 2017
    Pretoria, South Africa
    Quote Originally Posted by doctore View Post
    here you goo check your wire on r270 plus gnd and restAttachment 580403
    Not working..
    Sent from my HUAWEI CAN-L01 using Tapatalk
  2. #17
    Dec 2018
    Latvia
    You try 512k or 256k?
  3. #18
    Jun 2017
    512k
    Quote Originally Posted by AndrewStone View Post
  4. #19
    Dec 2018
    Latvia
    Quote Originally Posted by BraLaas View Post
    512k
    Try maybe to remove device from computer and add it again, with new driver, and also did you try another cas?
  5. #20
    Mar 2013
    Europe
    Use other Programmer
    Your R270 work BAD
    My R270 show me same ERROR
  6. #21
    Oct 2017
    Hungary, Budapest
    Yeah, reinstall driver, use the one under R270's install folder. Once blowed my mind also with errors. And let R270 is a good programmer. Used long time ago, never "burned" any MCU....
  7. #22
    Dec 2018
    Latvia
    Quote Originally Posted by kaleval View Post
    You also have some problems with reading with MCU in R270, but drive was the problem? What MCU you done?
  8. #23
    pierre renault's Avatar
    Jan 2013
    If you have OM23S it is not supported by R270
  9. The Following User Says Thank You to pierre renault For This Useful Post:
    rtbdiagnostic (16th December, 2019)
  10. #24
    Dec 2018
    Latvia
    Quote Originally Posted by pierre renault View Post
    i'm its really less of this MCU?
  11. #25
    Jan 2013
    The color of the wire 24 in the image does not seem to be the one indicated on my R270 and pink!
  12. #26
    pepi's Avatar
    Hi there your wire colors are not ok ,remember wire 26 is GND with blue color.
  13. #27
    brahimdyag10's Avatar
    Aug 2016
    read with xprog if very easy
  14. #28
    Oct 2017
    Hungary, Budapest
    That time was a CAS2 from a 05' car, but same behaviour as discribed, yea reinstalled driver by giving the exact .inf file than worked well.
  15. #29
    Dec 2018
    Latvia
    Yes some times helps realy good
  16. #30
    Good day friends
    I have cas3+ from bmw e90 and need to do mileage correction.
    But when I try to read with R270 I get ID error
    Someone could please help it would be much appreciated
    Did you find solution ?? same problem :/
