Page 1 of 3 123 LastLast
Results 1 to 15 of 31
    Jun 2017
    Pretoria, South Africa
    Default Cas3+ read error
    Good day friends
    I have cas3+ from bmw e90 and need to do mileage correction.
    But when I try to read with R270 I get ID error
    Someone could please help it would be much appreciated
    Sent from my HUAWEI CAN-L01 using Tapatalk
    Dec 2018
    Latvia
    Double check the wire connection, i have same problem on CAS2 checked again wires, resolder it and go great
    Jun 2017
    Quote Originally Posted by AndrewStone View Post
    Thank you andrew will try,
    Have also made wires shorter
    Jun 2017
    Checked wiring and also made it shorter
    Still same error...
    Dec 2018
    Latvia
    Man check 7 wire i'm think you get it wrong, R270 have bad pictures, you need to solder it to board pin check please
    Jun 2017
    Like so..??
    Dec 2018
    Latvia
    Use microscope to see pins
    Jun 2017
    Do you mabe have picture for me please Andrew
    Dec 2018
    Latvia
    did you give power to R270??
    Jun 2017
    Yes I have
    Dec 2018
    Latvia
    Quote Originally Posted by BraLaas View Post
    Yes I have
    Give me MCU Mask, after lunch i will check if my R270 SW run, because i don't have with me right now
    Jun 2017
    0L15Y
  13. #13
    doctore's Avatar
    Nov 2015
    Colorado Denver
    if you tr many time with this tool
    probably you will not fire car again it will kill mcu
    Professional bmw key service cas 3/3+ 4/4+ repair = reset ews egs 8hp = 6hp-egs19d
  14. #14
    Jun 2017
    Do you mabe have pinout for R270
    Mabe I have bad wire adaptor..??
    Then I can mabe try female jumper wires
  15. #15
    doctore's Avatar
    Nov 2015
    Colorado Denver
    here you goo check your wire on r270 plus gnd and rest0b210901d401f4fe3f007dffa8522953.jpg
