Results 1 to 4 of 4
    Dec 2018
    Default Mercedes CLK W208 3.2 1999 ECU Swap
    Hi there!
    I have a problem ECU in a Mercedes W208 CLK with 3.2 engine. Original ECU is part number: 025 545 85 32. HW 39.97. FD 98M11 SW
    Replacement ECU is part number: 025 545 85 32. HW 39.97. FD 98M12 SW
    As the new ECU has a slightly different software number is this likely to work?
    I believe I need to swap an EEPROM anyway, but I'm unsure which chip this is? I've google Bosch chip numbers but not found the answer. I found chips marked: 30132 K7843 A7857, 290836, 183060, B57554, B57943
    Thanks in advance for any help!
    stanislav georgiev's Avatar
    Oct 2014
    България
    As far as I know, you should read Motorola MCU 68HC11E9
  3. The Following User Says Thank You to stanislav georgiev For This Useful Post:
    hydorah (22nd December, 2018)
    Jun 2010
    SWAP MOTOROLA HC11E9
  5. The Following User Says Thank You to lirinikut For This Useful Post:
  6. #4
    Dec 2018
    Default Thanks guys!
    Thanks for the replies chaps. With you info regarding a Motorola MCU; I've found something which I think is the MCU. It is square, has 52 legs and is made by Motorola and is marked zc432594cfn BB1037357075 B58289 4E28B QQBG9846. From Googling it would appear this is indeed that component to swap! Thanks guys I was looking at the wrong chips I think
    The bloke on this thread swapped that MCU and his Key/ECU/EIS/VIN programming was on that chip
    https://mercedesforum.com/forum/merc...w-range-52002/
