Your tuning dpf egr off file
Dyno tested 200hp and 430Nm
Pass PM
Pass PM
Chiptuning Files FileService, Damos Files
EGR/DPF/NOX/DTC/TVA/VSA/ADBLUE/Lambda OFF...
Licensed: WinOLS, RACE 2000, ECM Titanum, ESS
Master: Kess,Ktag, HPTuners,
no personal info in sigs !!!
dashtool2016 (15th December, 2018), MVRH (15th December, 2018)
brother can I try it on the car? Thank you
Yes pass sent
dashtool2016 (15th December, 2018), MVRH (16th December, 2018)
Thanks tested today very good
Hi Guys.
This is amazing. This is exactly what I've been looking for. The Leon FR170 that I've just bought is already remapped but I'm having issues with a bit of smoke at idle so I want to try flash it back to factory maps and work my way back from there.
I've posted "hello" in the introduction and waited 15min. Still can't download the files on this thread. Any ideas?
Thanks 👍
I believe so
Thanks for getting back to me. I just tried it and it failed while flashing. Luckily I was able to flash the original map back to the ECU and the car started again. I've tried it twice and it fails both times at 8%
Is your car the 2008 FR170 ?
I've got 2009(2008 actually) FR550 170bhp.
If it is would you be able to share the pass code with me for the Winols file you received.
Thanks in advance 👍
You can’t just flash a file post your ID up probably different software numbers
What tool you using as from id hardware same different software version so you’d better ask for your version to be tuned
I'm using MPPS. I actually want a factory stock map but it might be worth giving the guys my current map to see if there is anything wrong with it. It's smoking slightly on idle, but worse of all is the strong smell that's gets all over the car and on my clothes.
Ok thanks for the help!
gmon16 could you do one of these files for me? I would really appreciate it! My car is already remapped (bought it like that) and I don't know who and when the remap was done but I'm getting a bit of smoke and a engine shudder at idle. The fumes are really strong smelling. On the weekend I'm going to check to see if the EGR valve isn't clogged up and stuck open.
If I give you my current map, would you be able to tell me if it's got DPF and EGR off and if it's a good remap or not?
Thanks in advance 👍
