compare with the read you take off the car. that was already on the ecu.
Hi, yesterday i read Opel Astra Delco E87 for remap. I found out, that there is already done DPF OFF. Can i put this Dpf off file, then i will be asked for Ori file for doing checksum? DPF OFF file in winols shows cks ok and also mod is ckecksumed with winols.
HW: 55584317
SW: 55597679
SW ver.: G12037
Engine: A17DTS
HW Ver.: 86AA6PH020350288
SW upg.: 55595003
mancioks (18th December, 2018)
I was thinking so but i found post in other thread of DK:
"THANKS kinketotua but it doesn't worked. But I'm not sure if I have upload it well.
An upload I have made by KESS but there already was MOD (Swiftec solution).
By uploading file KESS asking about file to upload, then about file to compare (original) - so I have selected file SWIFTEC solution becouse it already was in ECU.
After that Car didn't start. ECU was alive becouse there was connection. Error was that FAP is clogged.
So I upload SWIFTEC solution choosing file as original to compare ORG file first readed not Yours DELCO_dpf_chck.mod and Car starts.
I'm wondering if when I upload DELCO_dpf_chck.MOD choosing ORG file if it will works? "
Thats why i'm little bit affraid
what is hp you have 110/130
130hp. I downloaded lots of e87 that i found in forums, but any file was same that i have.
Answer - YES, you can.
what type of kess did you use for write file ?? ORG kess or Clone kess?
Kess 5.017 china clone
If i helped, don't forget push thanks + rep
