Results 1 to 7 of 7
    Dec 2018
    Default 2008 FR 550 170bhp Original file needed
    Hi Guys
    If someone has the file or the same car as me, could you send me your original factory map?
    Seat Leon FR550 170bhp 2009(actually 2008)
    Hardware: 03G906018GQ
    Software: 4361
    System type: R4 2.0I PPD1.2 G
    Let me know if you need any more info!
    I have READ and SAVED the remapped file to my laptop and I need to write the original factory file back to the ECU using MPPS V13.
    Unless there is a way to reset the remapped file back to original , let me know and I can send you the file.
    Thanks in advance guys 👍
    Dec 2018
    Just in case someone out there knows what the issue might be , I bought the car recently (already remaped) and it rough idles and smokes slightly at idle. It's not a lot and it's not black smoke but the smell is terrible. I'm thinking maybe the EGR is clogged open? I might take it out and clean it on the weekend.
    I don't know if the remap has EGR and DPF off.
    Any thoughts on what the issue could be?
    file attached. ori obd read.
  4. The Following User Says Thank You to b44ly For This Useful Post:
    LomoMoon (20th December, 2018)
    Dec 2018
    Quote Originally Posted by b44ly View Post
    Perfect thanks a mil!!
    Dec 2018
    B44ly do you have much experience? I've flashed your map and it's successful and I can feel that the car is back to factory power and all that extra boost is gone. However I'm getting a flashing glow plug sign on the dash. I've cleared DTC codes but I'm still getting
    P0546 OBD-II Trouble Code: Exhaust Gas Temperature Sensor Circuit High Bank 1 Sensor 1
    I'm starting to think this DPF has possibly been removed by the previous owner and DPF deleted on the map. Any thoughts?
    Dec 2018
    b44ly here is the map attached that was originally on the car. If you get a chance some time could you see what is going on with it? See if it has EGR delete/ DPF delete ?
    Thank you very much. I owe you for all your troubles!
    Dec 2018
    Has anyone else got a stock map that I can test?
