Results 1 to 3 of 3
    felix_fetche's Avatar
    Baia Mare
    Default Smart 454 FourFor PCF7941 Issue
    If i put the key in zeddbull i can read it, it takes about 10 seconds, and read that is ID 46 CRYPT Philips, 7941 Locked.
    Car don't start with this key, if i try to relearn transponder with Star Diagnose it gives error "Transponder Defective" and cannot learn it.
    What can i do? To put another new PCF7941 ? Needs preparation before learn procedure?
    What about using a PCF7936 and pull out the communication solenoid from key PCB? Or PCF7936 need also preparation, or just use a blank?
    Give you thanks+rep.
    hi its already coded into another car, sent you pm
