    mexanico1971's Avatar
    portugal
    Default Renault CAN CLIP firmwares
    I"m searching clip new firmwares 140 up to new versions
    Than"k in advance
    Best regards
    My work is my life ART TECH GARAGE
  2. The Following User Says Thank You to mexanico1971 For This Useful Post:
    sebastia (9th November, 2019)
  3. #2
    Member JareckiPL's Avatar
    Dec 2013
    What about v179?
  4. The Following User Says Thank You to JareckiPL For This Useful Post:
    mexanico1971 (26th December, 2018)
  5. #3
    portugal
    Quote Originally Posted by JareckiPL View Post
    What about v179?
    Thank"s but I need Firmware , not software
    Brs
  6. #4
    Louislesinge's Avatar
    Jun 2017
    French Jungle
    Hi Mexanico,
    What are looking for? The firmware of the probe (RLT2002 or Alliance), Reprog that contains the ECUs updates or CLIP? The updates for the probes are included into CLIP: if you want to update the probe firmaware (if probe works), install CLIP selected version , update the firmware and go back to your favourite Clip version.
    If you only need probe firmware for on the bench update, tell me where to find it in CLIP software.
    Greetings,
  7. The Following User Says Thank You to Louislesinge For This Useful Post:
    mexanico1971 (27th December, 2018)
  8. #5
    portugal
    Quote Originally Posted by Louislesinge View Post
    Hi Mexanico,
    Greetings,
    thank"s for input
    I got the 20% / 74% error firmware
    I all ready check 32k oscillator and solders in the PCB"s and still no luck
    All Led"s are ok , and I would like to try reflash the PSOP 29f800 before change the AN2135sc
    Thank"s
    Salut
  9. #6
    Dec 2016
    PL-GB
    Hi, i have this same error on 74%. Do You repair Yours Clip? thanks
