Post errors, maybe You lost synchronisation ECU with CEM and lost injector codes
Hi guys, I need help,
Tried to read volvo v50 edc16 80kw via obd with kess v2 clone, when i try to read ID instrument cluster starts to blink and i get and error.
So i BDM ecu with k-tag, read ecu, deleted egr and wrote file back to ecu...
No when i connect ecu to the car i cant start it...
I get faults in all 4 injectors....
I tried to write original file back to the car, but nothing happens, same errors plus egr....
Any thoughts, what to do ?
I attached org file also.
Thanks in advance!!!
Your supposed to backup injectors in case of total loss - you can code injectors back in with diagnostics equipment , although your other problem as i have experienced in the beginning of my journey cheap bdm probe with wrong layout actually damaged the ecu .
Did you make bdm probe yourself or use china or something else
Sorry was on vacation....
I will post error codes in a few minutes.
I soldered wires directly to the ecu.
Here are the error codes....
Išsiųsta naudojantis SM-G950F Tapatalk 4 Lt
Also this in ABS, but car had this error when it started also
