WV Passat B6 need pin code
Results 1 to 15 of 29
    Oct 2017
    Europe
    Default WV Passat B6 need pin code
    Passat B6 2006 won't start because of faulty electronic column lock module,bought new one from dealer,tryed extract login code via Vag k+can commander,launch x431 and carprog from instrument cluster,all gave me 65535 code.
    When i go to 25 immobilizer,press login and it refuses key.Key refused in ecu also.
    What exactly procedure to adapt new ECLM module.
    I readed eeprom with vag k+c commander.Passat EVL dump.rarpassatb6.txt
    Dec 2018
    I would have modified existing steering column to bypass lock.
    I would use FVDI or Similar or VCDS maybe fault is not in column .
    On MB we read EPROM and modify so steering lock remains off not sure on VAG
    Its possible the pin tool suggested is wrong and you’ve alienated key
    Dec 2018
    Some China vcds also functions not working correctly
    Oct 2017
    Europe
    Maybe i can read edc16 ecu via BDM and turn off immo at all? Will it work?
    Dec 2018
    I know edc16 immo off works but I’m not sure if what you have already tried changes that but can only try
    Oct 2017
    Europe
    You can make immo off of edc16 ecu?
    Dec 2018
    No but if you post in chip Tuning or immo I’m sure someone will bud
  8. The Following User Says Thank You to MVRH For This Useful Post:
    arejas (22nd December, 2018)
    Aug 2015
    ok mate, first of all 65535 is = 0 so it is not pincode since b6 does not store pin in instrument cluster, you can read pin code from edc16 ecu since that year is PD engine , or remove CCM module and read eprom for pin code
  10. #9
    Oct 2017
    Europe
    so you say 65535 is not a pin code?
  11. #10
    Dec 2014
    PL
    Hi.
    "Vag Can Pro" reads IMMO PIN from edc 16 VW B6 2.0 PD 8V. The Immobilizer is together with a comfort module. Behind the storage box not in instrument cluster.
  12. #11
    keygargoil's Avatar
    65535 = ff ff in hex which is a blank read
  13. #12
    Aug 2015
    Quote Originally Posted by arejas View Post
    as i said, no, 65535 is blank and definetly not a pin code
  14. #13
    Oct 2017
    Europe
    can vag can pro 5.5.1 do it?Or for example vag k+can commander 3.6?
  15. #14
    Dec 2014
    PL
    Vag Can Pro 5.5.1 can read pin immo in VW Passat B6 2.0 TDI. (OCF) I have 2.0 TDI BMP 2006my and read.In the description of vag commander 3.6 it is read in the VW Passat until 2006MY.
  16. The Following User Says Thank You to Mario6 For This Useful Post:
    opflorin (29th October, 2019)
  17. #15
    Sep 2016
    Default pin code please passat b6
    hI,
    Please help me with pin code for passat b6, i need to change the elv.
    Thank you in advance,
    Alin
