Results 1 to 4 of 4
    Default psa edc16c34 repair
    HI, i have already changed 3 of edc16c34 ford-psa with same problem
    NO CAN COMMUNICATION FROM OBD or PINOUT .
    in bdm all OK ,I CAN read and write
    no short , power consumation OK like good ecu
    have you any experince with can lines?
    i have tried to change 30622 ic in the corner with new , but with new , ecu not turn on
    repalced with old and stil power on and bdm commiucation. is it preprogrammed (there is a little oscillator near)?
    i hope can you help more.
    Nov 2011
    Maybe there is no problem with ecu but the could be a problem with a car
    is ecu problem as i told. copy in bdm in other ecu and all is ok, also is not sw problem, already test with an other full bdm
    May 2024
    Quote Originally Posted by marcoco View Post
    I wonder if you sorted problem out? I have problem the 3.3V regulator seems not to work.
