Results 1 to 15 of 22
    Dec 2018
    Default Aairbag light is ON . PLEASE HELP WITH FAULT CODES.
    Hi everyone,
    i have a dacia sandero 0.9 2014 with the airbag light on.
    i am having the following fault codes .
    DTC80DF66
    DTC80D223
    DTC80D224
    DTCF00316
    90800429
    can someone please help me.
    Thanks in advance
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    tried clearing it with scanner if so what caused the codes
    Dec 2018
    tried clearing it with the scanner but would not clear.
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    had impact?
    if so post dump from srs module maybe 95160 eeprom or spc560 d-flash
    Dec 2018
    hi, yes it had been in an collision but no airbags were deployed.
    could you please tell me how i can get the crash data and post it here,
    joker01's Avatar
    Jan 2018
    devi leggere spc560 con programmatore upa, xprog o simile ...
    Dec 2018
    i got the crash data reset , however airbag light is still on.
    i checked the codes and the following 2 codes are on :
    DTCF00316
    90800429
    it does not let me clear the codes.
    someone please help
    Autotecno2006's Avatar
    If you can not clear faults then CRASH DATA in your Module is not Cleared correctly ! Get original file & post here ok !
    Dec 2018
    thanks but i sent to to someone from ebay to clear the crash .
    thats why i am not able to put the crash data on here. i dont know how to
    Dec 2018
    The person that cleared the data is saying that they cleared it few times .
    so does everyone think it needs to be reset again?
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Quote Originally Posted by Thiss098 View Post
    Get them to send you original & cleared data
    Dec 2018
    just heard back from the company,
    they are saying that it is probably an issue with the module itself.
    they are able to send me the orginal file but the new file is inside my module which i cant obtain.
    would anyone be able to see from the orginal file if i need a new ecu , or the codes can be cleared.
  13. #13
    Oct 2010
    Which company cleared for you?
  14. #14
    Dec 2018
    Dec 2018
    a company from ebay
