Hello. i want egr off on Astra G 2.0 dti. Can i read with galletto on obd? If i dont can, wich is other way to read map? Thanks for help
You can't read this ECU, only write.
Post here the identification screen with Galletto.
NO PASSWORDS FOR ANYONE, EXCEPT THE RECIPIENT OF THE FILE !!!
If your PM box is full, clean it right now...
Otherwise, your requested file will be deleted... for ever!
cupsi (24th December, 2018), stanislav georgiev (24th December, 2018)
Can read with other tools? I must see indetification and find same map, than turf off egr and write? I dont have now indetification, should be tomorrow work on that car.
There is not any tool, which can read the file from this ECU.
Yes, you must find the file from ECU with same numbers (from identification) and go ahead...
Ok, thanks very much for help.
