Results 1 to 5 of 5
    Mar 2018
    Serbia
    Default Opel Astra G 2.0 dti help
    Hello. i want egr off on Astra G 2.0 dti. Can i read with galletto on obd? If i dont can, wich is other way to read map? Thanks for help
    bobolin4o's Avatar
    Bulgaria, V. Tarnovo
    You can't read this ECU, only write.
    Post here the identification screen with Galletto.
  3. The Following 2 Users Say Thank You to bobolin4o For This Useful Post:
    cupsi (24th December, 2018), stanislav georgiev (24th December, 2018)
    Mar 2018
    Serbia
    Can read with other tools? I must see indetification and find same map, than turf off egr and write? I dont have now indetification, should be tomorrow work on that car.
    bobolin4o's Avatar
    There is not any tool, which can read the file from this ECU.
    Yes, you must find the file from ECU with same numbers (from identification) and go ahead...
  6. The Following User Says Thank You to bobolin4o For This Useful Post:
    Mar 2018
    Serbia
    Ok, thanks very much for help.
