Results 1 to 14 of 14
    DK Veteran BeianM's Avatar
    Dorset UK
    Default Iveco Daily Speed Limit remove
    Hi, can anyone remove the speed limit of this file. This vehicle is fitted with a tacho.
    Many thanks in advance
    waldi1979's Avatar
    Dec 2010
    You can write this file - w/o limiter.
  3. The Following 3 Users Say Thank You to waldi1979 For This Useful Post:
    BeianM (25th December, 2018), campomarino1993 (29th December, 2021), nikolani (25th March, 2021)
    Dorset UK
    Hi, many thanks.
    This is actually fitted in an Optare Alero minibus. Based on Iveco drivetrain. There are many owners in my group who have converted the bus to motorhome & need this limiter off.
    Lots of different code in this file I assume it is a virgin file? I read on DK that unlimited file in ecu does not work when vehicle fitted with a Tacho.
    Also, will this file allow Cruise Control?
    I have been looking for Iveco software to do this but can't find a working download link.
    I will try & let you know.
    Cheers
    Brian
    Meat-Head's Avatar
    Not sure but go pester lupusandu
  6. The Following User Says Thank You to Meat-Head For This Useful Post:
    waldi1979's Avatar
    Dec 2010
    I tested this solution few times and it always was working but I don't know if CC will work (my cars didn't have it).
  8. #6
    Dorset UK
    Yes working here too. Just come back from test drive. Can I flash this to other vehicles, looks like a virgin file. I'll fit a CC stalk & report back.
    Thanks again for this.
  9. The Following User Says Thank You to BeianM For This Useful Post:
    Meat-Head (26th December, 2018)
  10. #7
    Meat-Head's Avatar
    What did you read and write this with please
  11. #8
    waldi1979's Avatar
    Dec 2010
    Quote Originally Posted by BeianM View Post
    Yes, if you have 814.043S engine.
    Immo data are stored in 24C16.
  12. The Following User Says Thank You to waldi1979 For This Useful Post:
    BeianM (26th December, 2018)
  13. #9
    Dorset UK
    Thanks again, could not see this ecu in nyo. Is this also map data, Bus seems more powerful, but could be my imagination. Could do with re-mapping.
    Have found this https://www.digital-kaos.co.uk/forum...aily+tuned+map
    Looks to work with Cruise Control
  14. #10
    Dorset UK
    OBD1260 & EOBD2 soft (serial 1260) done in seconds.
  15. The Following 2 Users Say Thank You to BeianM For This Useful Post:
    DrLoopyTunes (17th January, 2019), Meat-Head (26th December, 2018)
  16. #11
    Jan 2019
    Poole
    Hi Brian - I also have an Optare Alero and I am trying to remove the limiter, but I can only find an Iveco connector (round one with loads of pins)
    How did you connect your OBD-II? Once I get connected, I assume I just download the old one (in case the new one doesnt work) and upload the new one?
    Thanks!
  17. #12
    immokill's Avatar
    Jun 2009
    UNIVERSE
    U can do it by wire
    I read like rhat conect obd with wires to iveco cobector and it works.
    Here to HELP!
  18. The Following User Says Thank You to immokill For This Useful Post:
    DrLoopyTunes (18th January, 2019)
  19. #13
    Jan 2019
    Poole
    That's fantastic - thanks for your help!! Just need to check I have the right engine series before I screw it all up...!
  20. #14
    Dorset UK
    Hi sorry I only just come back to this thread, how did you get on? Most adapters are wired incorrectly. I piggy-backed a obd socket onto the k-line & power.
    I see you are in Poole, so am I
