Results 1 to 1 of 1
    Dec 2018
    Mid US
    Default Maxforce 13 International
    2013 international prostar.
    coulple things starting with performance issue just started.
    Water separator fills up to the top within 60 seconds after replacing the 2 filters. There is. O air leak as from around the separator container no airbubbles just straight fills to the top. This started after a Truck was and thought a sensor, realized bad gas and used diesel treatments. Then we replaced both fuel filters and continues same problem. The truck will run up to 75 mph on flat roads any inclined and falls flat on its face to 50-60 mph. I have noticed a oil leak as well and maybe part of the issue. I’m not sure what this part is called but it’s next to the inter cooler on the drivers side.
