Results 1 to 14 of 14
    Apr 2016
    uk
    Default Opel keys renewal
    Hi guys
    I have a few Opel/vauxhall keys that I want to renew.all 2 buttons Delphi,valeo and Siemens.probably astra h,Corsa d and zafira b.
    Delphi:
    13.188.285
    13.189.115
    13.387.369
    Valeo:
    13.149.660
    Siemens:
    13.213.488
    I want to renew all..I have vvdi prog.
    Can someone please help with the renew files?
    Thank you
    vsanyi's Avatar
    Aug 2012
    I have these.
  3. The Following 8 Users Say Thank You to vsanyi For This Useful Post:
    bajad (27th December, 2018), castin (30th December, 2018), comizelu (27th December, 2018), klauss78 (25th March, 2022), krpic (19th February, 2021), lion0304 (19th April, 2021), richard27 (28th December, 2018), super jumbe (14th June, 2019)
    Apr 2016
    uk
    Quote Originally Posted by vsanyi View Post
    I have these.
    What tool do you use to unlock these keys?
    I have vvdi prog...
    vsanyi's Avatar
    Aug 2012
    I have vvdi prog...
    Yes.Vvdi prog and x300dp plus
    Dec 2018
    Hungary
    X300DP PL: Failed to connect to adapter
    What have I done wrong? I also cut the wire.
    13.188.281
    jodge's Avatar
    Mar 2017
    There is no perfect prommer but you will struggling with obdstar products for sure. Try it with vvdi, mk3, abri, kd..plenty of other tools supports this
    Dec 2018
    Hungary
    Apr 2018
    Did the wire connected or welded well?
  10. #9
    Dec 2018
    Hungary
    The wire is soldered. All 4.
    The wire is cut on the panel.
  11. #10
    P&D's Avatar
    Can these be unlocked ?
    Thx
  12. #11
    Mar 2018
    UK
    Baracuda has this model but read mixed feedbacks so I'm not sure
    I have one used in stock but never tried to renew it
  13. The Following User Says Thank You to Manta1600 For This Useful Post:
    P&D (18th April, 2021)
  14. #12
    Dec 2020
    I've renewed 5-6 Opel keys (Corsa D, Astra H, Zafira B..) with Obdstar x300, surprisingly it works perfect..
  15. #13
    P&D's Avatar
    Quote Originally Posted by Antonio266 View Post
    Renew 1000's but thats not the Question
  16. #14
    Dec 2020
    Quote Originally Posted by P&D View Post
    I wasn't answering to your post, anyway for your key i've seen it only on Barracuda diagrams, don't know if it works..
