This car will not run ok without working valvetronic system!
And how the engine works now, except that the MIL is ON?
Are you tested on the road?
Anyway... My point was, that with deleting errors from the file - there will be no any difference in the engine behavior. So if you like how the engine works with ~~~~ed valvetronic - go ahead with erasing errors, even all errors if you want...
Here is your file.
Keep in mind, that if you have started the engine after reading, then the virtual eeprom is changed, so you will be not able to start the car after flashing my file, and with ori file too...
WinWoj (28th December, 2018)
I found this fault in dtc table, now looking for sw table... But maybe someone has done it.
About this virtual eeprom. You suggest to read it again in boot mode using KTag for insurance?
If you have start the engine meanwhile - YES!
Thanks a lot. I bring this car to my garage and will make all security readouts including cas/ecu_boot files.
Hi Bobo, I was very carefully in this project, so I read it again using KTag, also CAS. I decided to switching off 3 dtc connected with valvetronic, please check if correct. I export with no-cks and cks-ok because not sure what file should be written via bdm.. I think cks-ok, but if you can, please confirm. File crypted, only for Bobolin4o.
BR
WinWoj (30th December, 2018)
