I know it's been a while since you posted, maybe you don't even have a car anymore, you managed to delete the error, if so how?
Hello, does somebody have similar situation?
Address 37: Navigation (J794) Labels:| 1K0-035-27x-37.clb
Part No SW: 3C0 035 279 D HW: 3C0 035 279 D
Component: RNS315-EU H32 0263
Serial number: VWZAZ2L3383652
Coding: 000004310400110000008000
Shop #: WSC 00015 115 00000
ASAM Dataset: EV_RNS315EUV2UDS A01004
ROD: EV_RNS315EUV2UDS.rod
VCID: 244DB1532FDBF86A92-8070
1 Fault Found:
1048642 - Internal Control Module Memory Check Sum Error
B2000 42 [009] - General memory failure
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 4
Fault Frequency: 1
Mileage: 81330 km
Date: 2015.07.10
Time: 18:37:07
I should try to update Sw to 270 or solder something? Actual mileage is 137000km
1048642 - Internal Control Module Memory Check Sum Error....your radio is broken.
I can repair it
