I had the same problem
And when i used p199 all is ok
r_parev (12th February, 2023)
Yes I tryed but dont work. Solution?
Had problem with "Microprotection removal failed". Tried it with serval protocolls and also with byteshooter and does not work. But my ECU was tuned from an other guy. My theorie is, other guy has changed anthing for noread.
Solution was new flash with ODIS. After them i could read it
My ecu is edc17c46.
should I first remove the protection via obd and then read with ktag?
Solutions???
the pinout for edc17cp14 is different than c46.
How is it possible? did you read the file correctly? both micro and eeprom?
Post id, and we give ori vr file. then you can flash over obd
Sedat Garip
Chiptuning Remapping, file service, stage 1 & 2 dyno tested.
Diesel + petrol All cars
Manual Adblue dpf egr Opf tested working solutions
Belgium
With Kind Regards,
Don't forget hit thank button if i helped.
It did not work in protocol 199 in Protocol 269. I solved by reading and writing with Fgtech. Thanks to all.
Probably the reading error is due to the power supply
I did not have +12
I'll try with 12v 5A power supply next time.
If someone has had the same problem, check this too.
