our immo off
Hello all,
Please help. Can someone please provide immo off for Peugeot HDI 301 EDC17C10 281 019 819 ECU
Tested solution would be better since vehicle is away.
EEPROM and Flash files are included.
Thanks in advance.
"I find your lack of faith disturbing"
If you found my post useful, please use the "Thanks" and "Rep" buttons.
our immo off
magnacin (31st December, 2018)
Thanks NOUNOU1212 I wil tray and post results
Dear Nou, files are exactly the same as the originals. No change was made.
no one has tested solution?
Test and report . Correct chm . Pass is in your pm .
regards
thanks antilo but your solution does not work.
Anybody has info? Carlab immo bypass works?
HI YOUR OFF
TRY AND POST RESULT
Thanks kino123, will try and advise later.
Kino123, your file worked perfect. Many thanks I really appreciate it.
hi bro i need inmo off please peugeot 301 2018 thank
[QUOTE = kino123; 3463663]HOLA TU[/CITA]
PRUEBA Y PUBLICA EL RESULTADO
HOLA PUEDES COMPARTIRME EL ARCHIVO? CARGUE UNO Y NO APAGA EL CHECK ENGINE.. GRACIAS
