Results 1 to 8 of 8
    DK Veteran zogldi's Avatar
    Space
    Default SID 807 EVO dpf off
    Hi I need help with this file. Peugeot 508 sid 807 evo need dpf off. This is generation 2 sid 807 .
    Space
    Somebody can help?
    Ignasvw's Avatar
    Feb 2016
    Lithuania
    Here file.
    Chiptunning / EGR / DPF / FAP / DTC / FLAPS / Adblue / ETC.... CUSTOM SERVICE / FILE SERVICE / 24/7 Support
    Nov 2011
    Try this file
  5. The Following User Says Thank You to PawelR17 For This Useful Post:
    zogldi (31st December, 2018)
    Space
    Thanks bro, I will try and report!
    Space
    Ignasvw dpf is off but I have dtc P0000. Can you solve this problem?
    Ignasvw's Avatar
    Feb 2016
    Lithuania
    write. pass same
  9. The Following User Says Thank You to Ignasvw For This Useful Post:
  10. #8
    Team dz's Avatar
    Apr 2017
    ALGERIA
    if not solved here this solision !
    Pass via PM !
    DPF / FAP / EGR / SCR / NOx / TVA FLAP .. etc
    Do not forget to press the button thanks and reputation
    # Algerian #
  11. The Following User Says Thank You to Team dz For This Useful Post:
