Results 1 to 12 of 12
    Default SAAB 93 2010 km change help needed
    Can somebody change km from 280xxx to 163xxx?
    IPC411 Diesel digitek.
    Original in atachement 9S12:
    Thanks!
    Dec 2018
    your File! tks
  3. The Following User Says Thank You to gabrielafortale For This Useful Post:
    tihiuvek (2nd January, 2019)
    Does not work!
    brend's Avatar
    Oct 2015
    Same where
    Here you go mate!
    Its good .
  6. The Following User Says Thank You to brend For This Useful Post:
    rafal (2nd January, 2019)
    brend's Avatar
    Oct 2015
    Same where
    If look this change edit algo, its look like totaly coctail ............
    Quote Originally Posted by gabrielafortale View Post
    your File! tks
  8. The Following User Says Thank You to brend For This Useful Post:
    gabrielafortale (2nd January, 2019)
  9. #6
    Dec 2018
    Quote Originally Posted by brend View Post
    I used this. Sorry if it did not work for you.
    Enviado de meu SM-G935F usando o Tapatalk
  10. #7
    brend's Avatar
    Oct 2015
    Same where
    And if look better ,in editor, nothing changed.!!!!!
    Changed dump is same like original.
  11. The Following User Says Thank You to brend For This Useful Post:
  12. #8
    Dec 2018
    The file I sent was this one. It's ok here. sorry only wanted to help friend. for some time he had expected an answer.
  13. #9
    Tanks Brend it is working correctly!!!
    Also Thanks for Gabrielafortale and your effort!
  14. The Following User Says Thank You to tihiuvek For This Useful Post:
    brend (2nd January, 2019)
  15. #10
    brend's Avatar
    Oct 2015
    Same where
    Press magic button..........
    Quote Originally Posted by tihiuvek View Post
  16. #11
    Reputation button does not work as I gave it positive reputation before.
  17. #12
    brend's Avatar
    Oct 2015
    Same where
  18. The Following User Says Thank You to brend For This Useful Post:
    tihiuvek (3rd January, 2019)
