Page 1 of 3 123 LastLast
Results 1 to 15 of 39
    Default Zenec zc-nc2011d
    Hi guys.
    This unit is stucked on logo.. can someone help with this? Need recovery firmware files..
  2. The Following User Says Thank You to jackie86 For This Useful Post:
    brecht77 (23rd June, 2019)
  3. #2
    Mar 2016
    Argentina
    Try this firmware to save it, good luck.
    https://wetransfer.com/downloads/d3a...2160041/611dfd
  4. The Following 2 Users Say Thank You to neutec For This Useful Post:
    brecht77 (22nd May, 2019), jackie86 (2nd January, 2019)
  5. #3
    Quote Originally Posted by neutec View Post
    Thank you. Is this bin file for flash or recovery files for usb/sd card? (Dont have PC now to view type of file).
  6. #4
    Mar 2016
    Argentina
    Extract ZE-NC2011D_V0403_FEU_Update.exe, copy C9_SW_Update to the root of SD OR USB boot, turn on the RADIO more instructions in pdf.
  7. The Following 2 Users Say Thank You to neutec For This Useful Post:
    jackie86 (2nd January, 2019), razvanrms (2nd January, 2019)
  8. #5
    Extract ZE-NC2011D_V0403_FEU_Update.exe, copy C9_SW_Update to the usb root, boot usb more instructions in pdf.
    I will try it, but i think that you files is for unit that can boot operaring system, than go to settings-update... i am not able to do that becouse is stucked on logo..
    Anyway, i will try tomorrow. Thank you
  9. #6
    razvanrms's Avatar
    Sep 2015
    romania
    dezarhivați fișierul ZE-NC2011D_V0403_FEU_Update pe o cartelă SD mai mare de 2 GB, formatată în grăsime32, cardul SD va găsi un fișier numit C9_SW_Update, introduceți cardul în slotul navei și re~~~~iți-l. sigla apare timp de 5unzip the ZE-NC2011D_V0403_FEU_Update file on a sd card larger than 2GB, formatted in fat32 the SD card will find a file named C9_SW_Update, insert the card into the ship's slot and restart.
    the logo appears for 55 seconds, then a window appears,5 de secunde, apoi apare o fereastră de
    dezarhivare a fișierului ZE-NC2011D_V0403_FEU_Update pe o cartelă SD mai mare de 2 GB, formată în grăsime32, cardul SD va găsi un fișier numit C9_SW_Update, introduceți cardul în slotul navei și re~~~~iți-l. sigla apare timp de 55 de secunde, apoi apare o fereastră
  10. The Following User Says Thank You to razvanrms For This Useful Post:
  11. #7
    i have tried to extract downloaded file to root of sd, but NO, it cant be done this way.. need recovery files, this is files for updating when unit boot up operating system..
  12. #8
    hi friends.. i still didnt solvemy problem with this unit..
    i have readed flash en29lv160 cb...
    does someon of you have dump for this flash, for this unit??
  13. The Following User Says Thank You to jackie86 For This Useful Post:
  14. #9
    Mar 2019
    Hello. Did you find a solution? I have that same problem. I couldn't figure it out.
  15. #10
    Quote Originally Posted by multimesut View Post
    No friend, i’ve returned unit to custumer
  16. #11
    Mar 2019
    Hello friend. my unit has been standing in this way for 6 months. couldn't find any solution
  17. #12
    Same story, i have returned 3 unit in last 6 months
  18. #13
    Mar 2019
    I am very surprised that there is no solution at all. I talked to the firm. says the firm needs to change the card. Get a new device to do it. very expensive. I think it is ridiculous. software problem.
  19. #14
    May 2019
    [COLOR=rgba(0, 0, 0, 0.87)]So how did you solve this problem?[/COLOR]
  20. #15
    May 2019
    [COLOR=rgba(0, 0, 0, 0.87)]Have you found a solution to this problem?[/COLOR]
