Results 1 to 15 of 15
    Dec 2016
    Default Peugeot Boxer EDC15C7 IMMO OFF needed
    HI!
    I need immo off for EDC15C7 in Peugeot Boxer from 2001 year 2.8HDI
    HW: 0281010486
    SW: 1037360012
    I post ori FLASH and EEPROM.
    Please someone make IMMO OFF or give instruction how to change dump.
    Will Rep and THX
    Kuba
    >>Genuine Winols, Swiftec, Ktag, Flex, x17<<
    >Diagnostic, Chiptuning, Dashbord<
    Feb 2017
    Eu
    @kubuswujo
    Correct cksm in writing...
    edc15c7 PSA (2-plug)
  3. The Following User Says Thank You to fabrag For This Useful Post:
    kubuswujo (4th January, 2019)
    Dec 2016
    @Fabrag i made checksum with mpps and your file not working...
    Car does not start.
    And to read this ecu on bench i had to unsolder immo eeprom. From information in forum i have read that to read EDC15C7 on bench via pinout i need to:
    unsolder eeprom
    or make immo off in flash.
    But when i have written your immo off solution, the car does not start.
    And after soldering eeprom i still cannot read/write it using kess or mpps. When i usnolder eeprom then i can read write ecu via pinout.
    so can someone send working solution?
    Feb 2017
    Eu
    Hi Kubuswujo,
    Sorry to hear that...
    The immo is in the flash (29F400) and nowhere else...
    Are u sure cksm is ok?
    You can try this file if you want (cksm ok)
  6. The Following User Says Thank You to fabrag For This Useful Post:
    HI YOUR OFF
    TRY AND POST RESULT
  8. The Following 6 Users Say Thank You to kino123 For This Useful Post:
    duckstar (17th August, 2020), ganbaa (26th July, 2022), kubuswujo (4th January, 2019), lufersanz (18th May, 2022), mikroel (28th March, 2019), petrevichmail (11th April, 2019)
  9. #6
    Dec 2016
    Thanks a lot.
    I will try tommotow both solutions i think that checksum were ok but i post file from mpps.
    Will report if it work.
    As i understand on good working immo of
    i should be able to read this ecu with eeprom soldered so it is easy to find out if immo off is working or not.
  10. The Following 2 Users Say Thank You to kubuswujo For This Useful Post:
    fabrag (4th January, 2019), petrevichmail (11th April, 2019)
  11. #7
    peko's Avatar
    hi friends
    which file working fine ?
  12. #8
    Dec 2016
    kino 123 works!
  13. #9
    Jan 2020
    Please, can you send me the pass? Thanks
  14. #10
    Dec 2021
    st Petersburg
    kino 123 can i have password. thank
  15. #11
    rafal's Avatar
    UK - PL
    Quote Originally Posted by boudjeka View Post
    read your ecu.................. and don't spam please
    https://www.digital-kaos.co.uk/forum...=1#post4361088
    need help
    now my goal is to buy xp-005
    who will help?
  16. #12
    Dec 2021
    st Petersburg
    hi Rafal. i dont have a backup. i have fix with imo decoding car not start
  17. #13
    Dec 2021
    st Petersburg
    I received 2 ecu the mechanic had already done the off with immo decidincg so I do not have the backups. That's why I want a safe solution.
  18. #14
    Jul 2022
    HI!
    HW: 0281010486
    SW: 1037360012
    Please someone make IMMO OFF .
    0281010486_ori.zip
  19. #15
    Your file Off
