Results 1 to 8 of 8
Thread: Interface a6c6
    Jun 2017
    Default Interface a6c6
    hello which interface / cable do you recommend for the diagnosis of audi a6c6?
    Oct 2017
    Europe
    I would definitely recommend VCDS.
    Jun 2017
    ross tech I find something cheaper?
    Dec 2014
    PL
    Here you have a little cheaper. Select the cable on ATMEGA 162 CHIP.
    https://pl.aliexpress.com/wholesale?...56&needQuery=y
    or here
    https://www.obd2cartool.com/index.ph...rd=vcds+atmega
    It can also be this.( vag can pro )
    https://pl.aliexpress.com/wholesale?...xt=vag+can+pro
  5. The Following User Says Thank You to Mario6 For This Useful Post:
    koranx (7th January, 2019)
    Jun 2017
    Ok, I understand, will all functions work?
    Dec 2014
    PL
    Yes it works. (Vcd$) However, I noticed that in some Audi there are no label files ( balloons with hints).
    Jun 2017
    ok, I order. I will test
    electronistul21's Avatar
    Nov 2011
    galati,romania
    you can use and VAS for this.
    Carprog 8.21,xprog 5.55,galletto v54,kess and ktag rework
