Page 13 of 16 FirstFirst ... 38910111213141516 LastLast
Results 181 to 195 of 227
  1. #181
    Jul 2022
    I don't know if there's any smarter way of doing this, but I took a look at some of the fixed 93C56 files posted here in a hex editor. A lot of the data is identical or empty in all of them, and I could use that insight to fix one myself. I put together this gif to make it easier to see which data is identical in all of the dumps. If your dump has different data in those areas, there's a good chance that you can just change it to be identical with the other dumps and it'll work fine. I don't know what any of the variable data is, but I have a sneaking suspicion that corruption there isn't as critical.
    It should also be noted that the two 220 µF/10 V capacitors in this ECU go bad and should be replaced when doing this repair. I suspect that they might be a part of what causes this problem.
    I used an 809H universal programmer to read and write the chip, though I had to desolder it for that to work.
    I hope this can be of help to someone!
    EDIT: The forum engine automatically turns gifs into jpgs (why?!), so I had to put it in a .zip.
    Attachment 967904
  2. The Following User Says Thank You to FFCCSa1F For This Useful Post:
    Rob6144 (1st April, 2024)
  3. #182
    Sep 2018
    Greece
    Mazda 3
    P0610 fault with not working cluster
    Checked the 93c56 eeprom and according to this thread everything seems to be ok.
    Can someone check the file for correctness?
    Thanks!
  4. #183
    Jun 2022
    Hello, can somebody help with this file ?
    Mazda 3, speedometer not working and dtc p0610.
    Can you correct file from 93c56 ?
    Many thanks
  5. #184
    Sep 2018
    Greece
    Just an update.
    Replaced 93c56 chip.
    Wrote the ori file and the p610 fault disappeared.
    Tachometer works .
  6. #185
    einet's Avatar
    Default Mazda 1.6 P0610 error
    Hello
    how can also help me to find the solution on this car ?
    I have tested many files and not work.
  7. #186
    gwiazdamb's Avatar
    Aug 2022
    PL EU
    Quote Originally Posted by einet View Post
    Hello
    Replace the memory with a new one
    PLEASE PRESS THE " THANKS " BUTTON
  8. #187
    einet's Avatar
    Hello
    Have chenged with a ST93c56 and error sill there.
  9. #188
    einet's Avatar
    hello, any can arange me only a Working Dump that not have error ?
  10. #189
    Nov 2017
    hello pleas help i have p0610 and speedo no work .Thanks
  11. #190
    gwiazdamb's Avatar
    Aug 2022
    PL EU
    Quote Originally Posted by turboo View Post
    Please....................
  12. #191
    Jun 2021
    Hi, please help i have p0610 and speedo not work, MAzda 3 2004 1.6 petrol
  13. #192
    Croatia
    Hello everyone, I'm pretty new to this thread and if anyone can give me some advice... On my own car, Mazda 3 BK 2004, 1.6 Tdi, I have a problem and I don't know how to solve it.
    When starting the vehicle, the vehicle could not start the electric starter. Ok, I thought the problem was classic. I have checked all the fuses, relays, removed the starter motor and sent it to the shop for repairs etc... And all of that is fixed but the car still won't start the starter motor.
    I realized that I have written DTC errors in the car and that's where the problems are.
    The errors are:
    PATS=B2139 (PATS (Passive Anti Theft System)
    data mismatch)
    Immobilizer module-PCM=P1260 (Theft Detected, Vehicle Immobilized)
    I have saved data from the engine computer because two years ago I did EGR-OFF and I tried to enter that program again in the car, but I didn't succeed.
    Does anyone have any advice on how I can solve this?
    I have MPPS V18. Is that helpful?
  14. #193
    Jun 2013
    EU
    Quote Originally Posted by bladeus86 View Post
    duplicated content, bad read, read it in 16 bit mode.
  15. #194
    Oct 2017
    Hungary
    Hi.
    I also have such a problem. Mazda 1.6 petrol with error code p0610.
  16. #195
    gwiazdamb's Avatar
    Aug 2022
    PL EU
    Quote Originally Posted by sancaman View Post
    Hi.
    The following errors occurred with your submission
    • sancaman has exceeded their stored private messages quota and cannot accept further messages until they clear some space.
  17. The Following User Says Thank You to gwiazdamb For This Useful Post:
    sancaman (26th April, 2024)
