Hi!
Please send the code again because there was no room in my folder. I deleted the old messages, so I can now receive them.
Hi!
The car works perfectly. thanks
Hello, help with restoring the EEPROM, the Mazda 3 1.6 speedometer does not work, the check engine light is on. Error P0610. Thank you in advance.
Last edited by vilin; 10th May, 2024 at 03:03 PM. Reason: Forgot to attach the file.
vilin (11th May, 2024)
Thank you very much, I will write an answer after checking.
Hello, Thank you, everything worked out.
Same error as the others. P0610, no speedometer.
EDIT: It's ok, I fixed.
There was a bit flipped. Fixed it with FORScan after checking each line's checksum in the PCM module.
I'm assuming the part is faulty, we'll see in the following days if it happens again, then I'll probably write it to a new part.
