Hi guys.
I'm here because I also have the problem with P0610 in ECU on Mazda 3 1.6i 2003.
I tried to find problem like s qubiakrepaired files. But it seems my dump is different.Can you please help me?
Hi guys.
Can te old EEPROM be swaped for new: M93C56-WMN6P ?
Hello . in my case the speedometer works. the error could not be deleted. I reprogrammed the forscan with the size of the tire and brakes in the engine control unit and it works
[COLOR=rgba(0, 0, 0, 0.54)]
[/COLOR]
[/COLOR]
Hi Guys... I have the same problem. Mazda 3 1.6 '04, speedo not working and DTC 0610 which cannot be removed.Could anyone help me, here is a dump from PCM ... Thanks
EDIT... Problem solved. Thnx s qubiak for no pass file. I compared the files, swapped the configuration blocks in ForScan and everything is ok, no DTC and speedo is OK. In the attachment my file after processing, maybe it will also help someone in the future.
hi guys,
i have same issue P0610 on ecu 279721-2970.
have upload with flash from ecu as well
Hi. Can AT93c56 be used instead of CT93c56? How critical is the manufacturer? I can't find ST anywhere in my country.
kdika (27th September, 2021)
Hi guys.
Please repair my dump. DTC P0610
thanks in advance
I have the same problem DTC P0610
dump in attach
nobody to help?
I have this same problem with my Mazda3 with (p0610).
Maybe someone can help me ?
Thanks and Regards.
