Page 9 of 16 FirstFirst ... 4567891011121314 ... LastLast
Results 121 to 135 of 227
  1. #121
    Feb 2017
    Hi guys.
    I'm here because I also have the problem with P0610 in ECU on Mazda 3 1.6i 2003.
    I tried to find problem like s qubiak
    repaired files. But it seems my dump is different.
    Can you please help me?
  2. #122
    Feb 2017
    Quote Originally Posted by websergei View Post
    Hi guys.
    P.S. Thanks. I've made it myself.
  3. #123
    Apr 2021
    Hello,
    I want to do it myself also, can you please elaborate on how you did it ? im using FORscan software.
  4. #124
    Feb 2018
    Can te old EEPROM be swaped for new: M93C56-WMN6P ?
  5. #125
    Mar 2017
    Hello . in my case the speedometer works. the error could not be deleted. I reprogrammed the forscan with the size of the tire and brakes in the engine control unit and it works
    [COLOR=rgba(0, 0, 0, 0.54)]
    [/COLOR]
    [/COLOR]
  6. #126
    Jan 2018
    Hi Guys... I have the same problem. Mazda 3 1.6 '04, speedo not working and DTC 0610 which cannot be removed.Could anyone help me, here is a dump from PCM ... Thanks
    EDIT... Problem solved. Thnx s qubiak for no pass file. I compared the files, swapped the configuration blocks in ForScan and everything is ok, no DTC and speedo is OK. In the attachment my file after processing, maybe it will also help someone in the future.
  7. #127
    Apr 2016
    hi guys,
    i have same issue P0610 on ecu 279721-2970.
  8. #128
    Dec 2020
    Quote Originally Posted by pramodp1621 View Post
    hi guys,
    Your dump doesn't look good to me..
    Try to clean eeprom and read again
  9. #129
    Apr 2016
    Hello,
    have upload with flash from ecu as well
  10. #130
    Sep 2021
    Hi. Can AT93c56 be used instead of CT93c56? How critical is the manufacturer? I can't find ST anywhere in my country.
  11. #131
    kiszka's Avatar
    Aug 2009
    Quote Originally Posted by kdika View Post
    it should work
  12. The Following User Says Thank You to kiszka For This Useful Post:
    kdika (27th September, 2021)
  13. #132
    Dec 2009
    Hi guys.
    Please repair my dump. DTC P0610
    thanks in advance
  14. #133
    Jun 2010
    Hello,
    I have the same problem DTC P0610
    dump in attach
  15. #134
    Jun 2010
    nobody to help?
  16. #135
    Oct 2014
    I have this same problem with my Mazda3 with (p0610).
    Maybe someone can help me ?
    Thanks and Regards.
