Page 2 of 13 FirstFirst 123456712 ... LastLast
Results 16 to 30 of 193
  1. #16
    Sep 2009
    see pm and tray
  2. #17
    Dec 2019
    I am a new user from Greece and a driver of a Mazda 3 with the same problem...Because I am a noob, what is the 93C56 file?
    Does this solve the problem and if yes, what hardware or software is needed?
    Thanks in advance.
  3. #18
    Nov 2015
    POLAND
    Hello, I have the same problem, can you help me solve it?
  4. #19
    Mar 2018
    Hello
    Same problem here... Speedo doesn't work, DTC on
    Can someone help, please?
    Thank you and BR
    C
  5. #20
    Mar 2018
    Problem solved...
    Thanks to gege974
  6. #21
    Jul 2010
    HUNGARY
    Default MAZDA P0610
    Hi guys.
    Please repair my dump. DTC P0610
    thanks in advance
  7. #22
    May 2016
    Merhaba @gege974
    Aynı sorun ...
    Speedo çalışmıyor, DTC temiz
    Birisi yardımcı olabilir mi lütfen?
    yardımın için teşekkürler..
    mazda3 1.6 denso z601 eprom 93c56.rar
  8. #23
    May 2016
    @gege974@ Hello
    Speedo doesn't work, DTC clear
    Thank you for help..
  9. #24
    Jun 2013
    EU
    Quote Originally Posted by tunceroto View Post
    @gege974@ Hello
    Try this one
    Hope it works for you.
  10. The Following 2 Users Say Thank You to morgano For This Useful Post:
    tunceroto (26th February, 2020), Yhoni (18th December, 2020)
  11. #25
    Jun 2013
    EU
    Quote Originally Posted by nagybela View Post
    Hi guys.
    thanks in advance
    Hi.
    Try with this eep mate.
    Good luck.
  12. The Following 2 Users Say Thank You to morgano For This Useful Post:
    nagybela (27th February, 2020), Yhoni (18th December, 2020)
  13. #26
    Jun 2013
    EU
    Quote Originally Posted by SLAWEK666666 View Post
    Hi.
    Here file for you.
    Good luck.
  14. The Following User Says Thank You to morgano For This Useful Post:
  15. #27
    May 2016
    [QUOTE = Morgano; 3806112] Merhaba.
    İşte sizin için dosya.
    İyi şanslar. [/ QUOTE]
    Thank you for help
    Perfect Working
  16. The Following User Says Thank You to tunceroto For This Useful Post:
    morgano (26th February, 2020)
  17. #28
    Oct 2018
    Hello.I have code P0610.Speedometer doesnt work. Can someone help please?MAZDA 3 BK .rar
  18. #29
    Jun 2013
    EU
    Quote Originally Posted by Suprasss View Post
    Here fixed eeprom, this is one time help for you, not acceptable being here since 2 years and only 2 posts. COME AND HELP OTHERS WITH YOUR SKILLS next time no help with your statistics on forum. Be warned.
  19. The Following User Says Thank You to morgano For This Useful Post:
    Suprasss (12th March, 2020)
  20. #30
    Oct 2018
    Quote Originally Posted by morgano View Post
    Thanks mate.I appreciate it. I already repaired it.Your solution is same as mine. I joined 2 years ago so that i can read posts and learn about programming. Much work had me forget i joined here.I will try and help others wherever i can now
