to run WinHex as Administrator right-click on winhex, properties
wwweeeeee beer for all guys !!!!!
with a new version of winhex I succeeded !!
I had changed various cards sd, pc but the sw version had not occurred to me ahhahaha
it's a nice forum ... you are strong !!!
thank you all for your help in particular to the great morgano !!!!!
[SIZE=3][I][FONT=impact][COLOR=#ffd700]PUSH THANKS AND REP IF I HELPED YOU !!!!!!
morgano (14th April, 2019)
How to get this work bigger than 2GB card? I have tried 4GB, 32GB,64GB, but when tried to get files from ksuite, EEFFACE -error show up.
With 2GB card no any problems, have done some card's all ready. SO what i do wrong with larger cards?!?
pocinas (16th August, 2019)
Ensure cards make proper contact on kess pcb sd reader and try starting ksuite 2 or 3 times until it starts without the exception error.
Other way is go the CID way, faster, cleaner, less error prone
No problem with 4gb.....restart ksuite 2/3 time as suggested
Or what i tested yesterday, which dont know earlier.
Put card filled 00 to Kess and just connect Usb cable, dont turn on ksuite, just this should record/save new data content on sd card enought to next step.. then put card to sd reader and go fallow next step, the first 13 lines start from 00005070 and end 000005130 (apologize if i put too many zeros)
My post helps you? Please Hit Buttons
Hello everyone.Some time ago I solved the problem with the card. Exactly the same, over 2Gb EEEFace.
I managed to create a 2GB card, but no more.
I used the first page files. Is protocol 445 working for you? The origo Chinese card works for me,
but on the new no.
I can provide the image of the original Chinese.
